Ga door naar hoofdinhoud
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 Vragen Bekijk alle
Why Ipad 4 GSM no modem firmware after update?
After update to 10.3.3. (via ota) there's no modem firmware and always searching (imei is OK), then restart after some minute.
I've restored (via itunes) with same 10.3.3, then everything is OK, but after 2 days, when i insert sim (ipad in airplane mode) the same things happened :
searching & no modem firmware.
It was working well for 5 years, now my ipad is useless.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Such type of fault mostly appear after the force brick.This actually happen when baseband chip is not working as well or damage.If you have idea to open search on ifix it and rehot the baseband chip or search for faulty parts near baseband chip.If the problem is still same you have to replace it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
i have a plan to open it and try to fix it by myself, could u please show me where's the baseband chip position is ? if u can attach the image i will appreciate it...
thanks.
door
Voeg je antwoord toe
Andrew Liem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 373
