Ga door naar hoofdinhoud
The Razer Blade Stealth are a line of premium Ultrabooks by Razer. The latest model is the Razer Blade Stealth (2019)
Screen hinge isn’t closing all the way
When I close the laptop, the bottom right side usually tends to stay slightly open. This isn’t a huge deal, but it looks aesthetically awful. I own the 13 inch gunmetal model just in case anyone was curious.
Is dit een goede vraag?
4 opmerkingen:
Hi, i have a razer blade 15 and i have the same problem… the lid stays open. won’t close all he way
door
same when i close it it pops back up which model do u have i have the base model and did u find a solution?
door
Having the exact same problem on my RB15 Base model. Any solutions?
door
I think the lid is being held by magnets. It must be a problem with the magnets because the frame and the lid are perfectly fine
door
Voeg een opmerking toe
1 Antwoord
Have you tried opening up the bottom case to see if there are any screws for the screen hinge you can tighten up?
Was dit antwoord nuttig?
2 opmerkingen:
Would I have to open the entire bottom? If so no, I haven’t
door
I have this same problem on my stealth. It doesn’t close all the way on the left side. I heard it might b the battery but my laptop looks completely normal by the trackpad and the bottom of the laptop. Maybe it’s a magnet that’s not holding it in place. Let me know if anyone has found this fix
door
Voeg je antwoord toe
AvgJoe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,890
