Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Looking for an enclosure for MacBook SSD?
So my Macbook Pro Late 2016 has recently died from a water spill, I'm trying everything but I think the logic board is fried. I'm wondering if there's a way to potentially retrieve my data from the SSD, since it's able to be removed, and if so which enclosure or reader would be best for the one in this model (Late 2016, A1708). I've been looking around online and I found some for earlier models but I want to be sure before I order which one is right for this model. Any suggestions or recommendations would be greatly appreciated!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Oh No! Not good...
OWC is one of the few companies which make cases to house Apples custom SSD's. Sadly, the new function key model uses a still newer physical connection than what OWC offers in their cases so there is no means to gain access without leveraging a second MacBook Pro 13" Function Key system to host your SSD (swapping them out) then copy off your stuff to an external drive then pop the original SSD back in (if its larger).
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Dang, any update on if there’s any enclosures about for the SSD now?
door
Sorry no external case
door
I can help you getting your data of the device if you send me the ssd as I can put it in my macbook and send you all the important stuff you want :-) Sounds better then spending a lot on a new macbook just to void it's waranty because of swapping it's ssd out with the one of your liquid damaged macbook right?:-)
Cheers
Score 1
4 opmerkingen:
Sorry but I really don’t feel comfortable sending a complete stranger on the internet my hard drive with my personal information on it...
door
No problem, was just trying to help out. Maybe ask some friends with an similiar device?
door
Musti, do you know that this will actually work?I have the same story as OP but I have another macbook pro coming in the mail so I want to know if you have tried this before and that I can actually access the data on the drive?
door
Looking for an enclosure for this drive to get my data off as well. Any luck?
door
Voeg je antwoord toe
Taylor Manning zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 2,475
