Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
20 Vragen Bekijk alle
Why is my phone overheating and draining battery?
I already tried replacing the battery, but my phone still overheats with what would usually be my normal use. It now drains battery at least 5% in three minutes, and keeps overheating when I try charging it. Charging for some reason also seems to barely do anything. It will charge for an hour and only have an increase of 18%.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I found a couple things you could try here https://www.technobezz.com/fix-poor-batt... but it all seems to be pretty basic stuff to help the battery. Another problem could be the charging port, but I would suggest the tips in the link before trying to replace anything else.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sydney-Morgan Arthur zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,684
