Ga door naar hoofdinhoud
What is a good inexpensive Ram Tester
we work with 8500s, 10600s, and 12800s 204 pin ram pieces, and we're looking for a good testing unit that can test 1 piece at a time to see if it's working, and also to help identify mis-labeled pieces of ram or unlabeled pieces of ram.
i found a few units for around $3500, but we're not looking to spend that kind of money as we don't have that much mis-labeled untested ram. does anyone know a reliable inexpensive unit that would work well for this?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Have you considered using an old laptop with MemTest86? That's what I use to test ram, and it's a cheap option. I just have one plugged into an external monitor and I keep the rear panel permanently removed.
- Jasen
Was dit antwoord nuttig?
Score 2
1 Opmerking:
thanks.... i'll look into that
door
Voeg je antwoord toe
dollartripclub zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 11
Altijd: 77
