Ga door naar hoofdinhoud
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
431 Vragen Bekijk alle
Replacement Microphone for EMC 2134
Hi,
I replaced my disc drive on my 24" iMac 2134 - in the process I managed to break the microphone. Does anyone have suggestions as to what would be an acceptable replacement? Does iFixit sell one? Or is it possible to repair it? Basically I removed the two wires from the circuit board. Suggestions would be much appreciated.
Thanks,
Paul
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I'm pretty sure it's built into the camera board, you don't see the mic replaced often. If so here's the part: http://www.gainsaver.com/Catalog/Detail....
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you for your response but that is a link to the camera portion. The mic goes in through a different cable which has an detachable part that when you take the top case off comes off with it. Unfortunately I destroyed the connection when I removed the case. it looks something like this http://www.gainsaver.com/catalog/Detail.... but for the Intel 24"EMC 2134. Any other ideas? Thank you
door
I can't find the mic or the part number for it. The closest I could get is the cable part number 922-8158 & 922-8155
There a chance that a MacBook Pro mic would work. Here's one: http://www.usedmac.com/catalog/product_i...
door
You can buy the imac bezel bc that part of the Mac comes with the microphone
Voeg je antwoord toe
Paul Sednaoui zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,811
