Ga door naar hoofdinhoud
Should I replace the battery?
Hello there, I got a dead iPhone 7, so I tested the battery, and the only “weird” thing.. is that the battery is rated 3.8v… and on this one.. im having a reading of 4.1V…. maybe this overpowered issue is preventing the iPhone to turn on???
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No, your battery is fine. A fully charged 3.8V battery will typically measure ~4.2V.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Ohhh nice.. so there's anything I can check of why the phone is not turning on??? or it seems to be the logicboard that its fried?
door
You should give me more information on the history of the phone. what happened to it before it died, was it dropped, damaged, contact with water, repaired etc.
door
Well my sister says... that it was dropped, but several months before she was using it normally, one night she plugged the phone... and next morning she noticed the phone was off... and since that morning... the phone is off =(
door
There's a good possibility that the logic board suffered some damage, either physically or electronically. Sometimes the problem shows up right away, other times it only appears later on.
This type of problem requires a micro-soldering repair and is not a DIY fix.
door
Oh I seee... thanks god I got a friend specialized in micro soldering on apple devices... but thanks for you super help =)
door
Voeg je antwoord toe
jbermudez27 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 128
