Ga door naar hoofdinhoud
The HP OfficeJet 4630 is a wireless color inkjet all-in-one printer.
13 Vragen Bekijk alle
Always shows error of paper jam
As soon as the device is powered on the printer shows error paper jam. Full disclosure this issue started to happen after a cat peed on it. It worked for a couple of days and now it is showing the same error again
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
cat pee is acidic. this must have caused some parts in the board to corrode and shorted out
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Firstly, why did the cat pee on it?
Secondly, since something is shorted you should check for anything that seems broken and replace it.
door
Was house sitting a friends cat. He must have been confused or something to something so random.
I suspect something similar too. Will have it checked.
I was hoping that I might discover a simple hack that can resolve the issue.
door
Voeg je antwoord toe
Nishit Rao zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 791
