Ga door naar hoofdinhoud
Vraag afgerond
Touch screen does not work
I replaced the original touch screen after ripping the digitizer ribbon when I opened my iPod Touch 2g for the first time to replace the battery. However, even with the new digitizer, the touch screen will not work, but the home button does. I wonder, do I need all the little screws screwed back in place behind the battery as well as in all other places? Or should I try and get another replacement digitizer as I've seen in other posts that said they had to make multiple tries from different vendors from ebay?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You shouldn't need all the screws in-- if the cable is plugged in, it should be working (the button is a different system, so it might work even if the touch does not). I would suggest trying a different digitizer, it might just be a faulty one.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,659
