Ga door naar hoofdinhoud
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
LCD and Screen replacement
I removed the gold strip next to the battery above the home button flex when removing the LCD digitizer after front glass removal. Can I continue with the repair or is it now repairable?
Is dit een goede vraag?
1 Opmerking
You should upload a picture of it then others can help you.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The best way to find out is to test the new screen and see if it's responsive. I'm not entirely sure if it's just a heat dissipation piece or part of the sensor for the touch screen.
I know the back of the new LCD should have the film attached as well, so I can only assume that it's a heat dissipation piece.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Lainey Yancyfjgbmp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 174
