Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Note 5 (genoemd de Note5) is een phablet-stijl telefoon met stylus, gefabriceerd door Samsung en uitgebracht in augustus 2015.
*67 in text message?
I just happened to look at the contact number I was getting ready to text and saw that there was a *67 in front of the phone number. How did that happen? I didn't put it there. Does that mean the other person wasn't receiving my text messages?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Ok. First start with turning it off and on again. Then try a force restart
To force restart your device, press and hold the Volume down key and Power/Lock key on the device for 10–20 seconds. This performs a simulated battery disconnect
If that doesn't take, then you'll likely have to restore, which you'll want to backup your data
From a Home screen, tap Apps . These instructions apply to Standard mode only.
Tap Settings.
From the Personal section, tap Backup and reset.
Tap Back up my data to turn on or off .
Tap Backup account.
Tap the appropriate account.
Tap Automatic restore to turn on or off.
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
I went to contacts and made the number the default number and the *67 went away. But HOW did it get there in the first place? So when I sent text msgs to this person, does this mean they didn't get them?
door Deel
Probably not. You'll have to resend. The contacts thing was good to know. I'll keep that in mind
door Deel
If anyone cares (*67) is Caller ID blocking. I have a feeling someone at some point got a hold of the phone and wanted to try to send texts without wanting the person on the other end knowing where it came from.
door Deel
@avanteguarde cool to know! Thanks, bruv
door Deel
My problem is a certain number automatically gets a *67 added Everytime I try to text it. I don't understand this.
door Deel
2 commentaren meer tonen
Voeg je antwoord toe
Michelle Haith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 2,309
