Ga door naar hoofdinhoud
The Asus Republic of Gamers G20 is a small-form-factor gaming PC with enthusiast-level components and good performance. Released in 2014.
Screen frozen on ASUS startup screen.
PC won't proberly boot, gives me an option to enter BIOS, if I leave it, it will just stay on the ASUS logo and a black screen. Previously I had a problem with the PC after a failed update. Any help?
Is dit een goede vraag?
2 opmerkingen
Umm... Hi! I've been having the same issue and i'm wondering how you solved it. It would be great if you could get back to me, Thanks.
door
I have the same problem got it from my step brother and it worked fine, but then sat for about 4-5 months and now does this.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @robert1201,
what OS are you using ?
before any failed updates, do you encounter any issues, like bsod or poor performance of the pc?
I suspect either the operating system has crashed or hdd issues
If possible do a check on the HDD, hopefully inside bios has an option to test out.
check inside bios if your hdd is able to detect.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Robert Mullins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,087
