Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
iPhone SE turning itself off on lock screen?
Phone was dropped down the toilet. I tried to fix it using the isopropyl alcohol method. All seemed fine, but then the phone turns itself off when it's on the lock screen every time.
What's happening here? Is it the battery? (As it was replaced due to me ruining the original when I tried to remove it) is it the screen itself??
Also, which areas do I need to check to try and figure out what's happened.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
I think the power switch is short circuiting, causing the screen to cycle on and off.
Was dit antwoord nuttig?
could be also a battery issue.
Voeg je antwoord toe
Kim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 254
