Ga door naar hoofdinhoud
An Amazon tablet released in 2014 featuring a 7 inch HD color touchscreen display.
33 Vragen Bekijk alle
Where can I find the IMEI or MEID number
I have an Amazon Fire HD 7 (4th GEN) tablet and I cannot locate either of these 2 numbers. Specifically, I'm wanting to use my fire to accept square payments but the more research I do the more I'm learning this may not be possible.
Is dit een goede vraag?
1 Opmerking
You find the cereal number by going into settings under device find device options and click on it your serial number will be at the bottom hope this helps
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
  1. To view the SIM, IMEI, and Serial Number, from any screen, swipe down from the notification bar.
  2. Tap Wireless.
  3. Tap Mobile Network.
  4. Tap Advanced Network Settings.
  5. IMEI and SIM Serial Number will be displayed.
  6. To view the device Serial Number, from any screen, swipe down from the notification bar.
  7. Tap Settings.
  8. Tap Device Options.
  9. The device Serial Number will be displayed.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks for your response. I actually have to tap on settings on my noifications bar and then I am able to tap on Wireless. When I tap wireless I only have 4 options:
Wi-Fi
Bluetooth
Location-Based Services
Airplane Mode
Is my tablet missing information? Should I do a reset to factory defaults? I don't want to have to do this but will if I thought it would fix this issue.
door
Is there a "More" area you can tap on? If so, try that to be taken into your Settings then located and tap on "Wireless & Networks"
door
Simply type code *#06#
2 opmerkingen:
Type it where, if the tablet is your only working device?? I also am with Brenda Smith. Mine only have the same options.
door
On dial pad of iPhone brother.
door
You can find your serial number by going into settings under device click on device options and scroll down to the bottom your serial number will be there hope this helps
Voeg je antwoord toe
Brenda Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 60
Altijd: 20,856
