Ga door naar hoofdinhoud
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239 Vragen Bekijk alle
How to clean keys (spilled soda)
with the new keys,how to clean
Is dit een goede vraag?
1 Opmerking
how much soda and did it get into the keyboard?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Invert laptop,, and with mixed solutions of alcohol and hot water,
usually a shot Glass size of rubbing alcohol to pint of water,
adding one or two drops of dish soap.
dip brush face,, similar to hand washing brush into solution,
Rewetting all the keys, as you are scrubbing every detail horizontal
in each direction along keys.
Keep inverted always.
Dry with towel as good as possible-
Then apply vac hose direct from vacuum cleaner
to draw out any remaining moisture.
Dampen micro fiber towel corner 3" area, with just alcohol,
for final wipe down.
Add warm air flow from heater, or hair dryer, till surface feels warm..
Let cool, he should be good to go,,,
From now on, never allow liquids anywhere near electronics.
Create space that makes it impossible by anyone casually setting
anything near it.
Best of luck....
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sándor László zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 781
