Ga door naar hoofdinhoud
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
20 Vragen Bekijk alle
My LG V10 shows only black screen.
Hello friends,
I have a serious problem with my LG V10. my phone get turn on but show only Black light on display. First i thought Its the LCD problem, i brought new LCD and replace it but still i got the same problem with new LCD.
Can somebody tell me what the real problem is. If the problem with my motherboard then what is it.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Hello Praveen,
Try the following solutions;
  1. Check the Lcd and motherboard connector. If the connectors are somewhat black, the problem may be caused by the connectors being damaged.
  2. Assemble the phone EXCEPT for the steel side panels, the screws and the back cover. Turn the phone on and see if the problem has been solved. If so, then refer to my post in the LG V10 section.
  3. Replace the motherboard and see if the problem disappears.
Best of luck.
Was dit antwoord nuttig?
https://okadtech.com/learn-how-to-fix-lg... Just go and solve your problem and thanks me later
There are several backlight led power lines in LG V10 going from motherboard to display through the connector. You can tell if it's just a backlight problem by by shining powerful flashlight and checking if any image is present. Most likely LED is not getting power and this could be due to filter capacitors tied to LED power lines being bad or PMI chip which powers the LED being bad. So approach would be to identify the filter capacitors, test the filter capacitors for short and then replace PMI chip if necessary. Of course, with LG V10 already being 9 years old, it's not worth the bother unless someone is doing this for fun and hobby.
Voeg je antwoord toe
Praveen Maurya zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 1,810
