Ga door naar hoofdinhoud
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
iPad Air Charging issue...
When hooked up my iPad Air does not show a charging symbol. Im not sure if the battery is dead or if the charging port is malfunctioning. How could I know to order the correct parts? There has been no previous damage to the iPad.
Thanks,
Andy
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That is the conundrum DIY fixers face. If you haven't already done so, open up your iPad. The battery is usually the part that needs replacing. Still, once you have removed it you can probe it with a multimeter to see if it is holding a charge. At ~4.2V, it is pretty much full and at 3.5V it is pretty much empty.
If the battery is holding a decent charge and you're not getting the charging symbol, you may have a defective charge port or logic board issue. If the battery is dead, then it's probably the cause (but it could still be something else). If it looks like a charge port or logic board issue, it will require a micro-soldering repair and is not DIY.
Ultimately, the only way to know is to try known-good or new components.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
andystills zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,718
