Ga door naar hoofdinhoud
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
20 Vragen Bekijk alle
Repairing Air Injection valve (Error Code P2440)
I have a Toyota Corolla XRS 2006 Which has around 180 000kms on it. The engine light turned on so I took it to a mechanic and he told me that the error code was P2440 which was for the air injection valves near the motor. I looked around the internet and saw that there were ways to fix it but not a detailed enough one for me to follow. I have mechanical experience but I would like to try and fix it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I don't have any mechanical guidance for you, but I did a bit of googling.
Here's how to clean that valve:
And this is a diagnostic for a similar, P0505 error.
Also try poking around for solutions to P2441.
The only difference between P2441 and P2440 is that in the P2440 the SVS is stuck open instead of closed.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Ickaron zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 3,421
