Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
VRAM Modules Pads or Paste
Going to upgrade the Kaby Lake CPU to a i7, upon reassemble should I use thermal pads or thermal paste on the VRAM Modules of the GPU, if pads what thickness should I use 0.5/1.0/1.5 or 2.0, like the ones used by EKWB on there GPU waterblocks, if paste should I go with K5-Pro, or the same thermal paste I use on the CPU Thermal Grizzly Kryonaut/Arctic Cooling MX-4.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Normal thermal paste will work just fine.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
If using thermal pads, what thickness should I use?
door
Has anyone measured, please? I have to order right thickness and delivery is like 10 days.
door
iMac 27” 2017 has a gap between VRAMs and cooler plate around 0.75mm.
door
Hi,
so a squeezed 1mm thermal pad should be fine, right? Do you think I need to use a little more thermal paste on the GPU die, in order to have the contact with the heatsink? Thanks.
door
Voeg je antwoord toe
John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,095
