Ga door naar hoofdinhoud
Released March 2016, 7.0" Galaxy Tablet by Samsung.
20 Vragen Bekijk alle
there is a X mark on battery icon
I dont know if its the charger or the pin in the tablet that has something wrong. When i plug the charger there is a red X mark on the battery and it wont charge. I have to power off the device in order to charge it but I need to stay the evice open because i need things in here. Help how do i fix it?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
If you are charging it via your computer, switch to a charger.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
No, im charging it with its charger. But there still an X mark
door
Usually this means battery is bad or near end lift. Try to use the device till battery is completely drained then full charge again. Repeat this step for 2 to 3 times and if it still happen. You need a new battery.
1 Opmerking:
I’ve got a 51 located on the battery icon. What does that mean
door
Mine does the same thing but I just got a new battery so I know it’s not a battery problem.
Voeg je antwoord toe
aju shee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 13,604
