Ga door naar hoofdinhoud
When home button is clicked Once it does 6-7 rapid clicks
Hello I have a customer with an iPhone 7. I replaced the screen and the home button is odd. I click it once and the home button gives me about 6-7 rapid clicks. Is it the home button pressure sensor? How can I fix this.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hey!
Try to disconnect the Home-Botton connector from the flex cable behind the LCD assembly, remove the Button completely and resest all parts again. Then test it again.
Was dit antwoord nuttig?
2 opmerkingen:
Tried that still having same issue.
door
Okay, in this case - if you are really sure all is sitting in place and is connected correctly - it could be possible the flex cable or button itself was killed. I rememvered the button and its board sticks very hard at the back of the LCD assembly and needs to remove carefully. Maybe you detect any damages at the board or cable?
And I think you should try another home button-flex.
door
Voeg je antwoord toe
Hunter Kegher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 677
