Ga door naar hoofdinhoud
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
147 Vragen Bekijk alle
Touch Screen Not Working
hey .
I got ipad pro 9.7" which felldown on the floor and touch screen stop working ..it is not even broken i do restart by power button nd home button still nothing , now i open the ipad put new lcd reconnect the battery ,,,,but nothing ...
Can u plz help me???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Is your iPad recognized by an iTunes enabled computer when you connect it? If it is, it means the the iPad is working but not displaying an image on the screen. You could try to shine a bright flashlight on the screen to see if there is a dim image. If this is the case, then you either have a damaged screen or a damaged backlight circuit on the logic board.
If the iPad is not recognized by iTunes, then you have a logic board issue.
If you believe the screen is at cause, you find one here. As for guides, there are only partially completed guides for now. The problem with the iPad Pro series is that parts are very expensive and that makes troubleshooting it yourself not worthwhile. I would take it to a reputable shop, preferably one that has parts in stock for this model. They will be able to isolate the issue properly.
iPad Pro 9.7" Screen Afbeelding
Product
$179.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
They said the touchscreen doesn't work as in the touch part as in it doesn't recognise touch. Same thing happened to me. This answer isn't helpful because you think the display isn't desplaying.
door
Voeg je antwoord toe
Zahid Mehmood zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 2,574
