Ga door naar hoofdinhoud
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
volume button not working
The top of the two volume buttons is stuck and doesn't work.
Are the buttons replaceable ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes, you can replace the buttons or the button flex (or both if necessary). It will require that you remove the glass/digitizer to access the inside. The iPad mini is one of the more difficult tablets to repair and there are lots of "gotcha's" when re-assembling (which is not covered in the guides).
I would start by looking through the repair guide first. There is no Volume Button guide for the iPad mini but the Logic Board guide will show you how the mini is assembled and the iPad Air Volume Button guide will show you how the button flex is installed (it uses the same flex as the mini).
Take note of what tools and parts you need and then determine if this is something you want to do yourself. Otherwise, look for a repair shop that has a lot of experience with iPad mini's .
Fix an unresponsive power or audio button by replacing the internal switches with this cable assembly. Afbeelding
Product
iPad Air and iPad mini Volume and Power Button Cable
$14.99
iPad Mini Wi-Fi Logic Board Afbeelding
Handleiding
iPad Mini Wi-Fi Logic Board Replacement
Moeilijkheid:
Zeer moeilijk
1 - 3 hours
iPad Air Wi-Fi Case Button/Cable Afbeelding
Handleiding
iPad Air Wi-Fi Case Button/Cable Replacement
Moeilijkheid:
Moeilijk
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Morgan Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 3,347
