mmm...
If you haven't bought your system yet I would get the bigger straight SSD model (sans the HD). Getting the needed SATA cable is not hard. But getting the custom Apple SSD is quite difficult! Get the largest you can afford. Then for now just get an external Thunderbolt or USB HDD drive.
In a year when the warranty has expired think about upgrading the system with a second internal drive. By that time the SATA SSD options will be cheaper.
Opening up the newer 'Thin Series' is a bear and if you're not careful its quite easy to damage the display which would be a very expensive Opps! Besides Apple won't honor any warranty repairs (first year) if you've opened the system.
2 opmerkingen
What are you trying to achieve with this move? Have you studied the concept of a fusion drive setup?
door mayer
fusion is based on optimizing io-performance through storage-tiering with fast and slow drives
wanna split the fusion drive and have only SSD storage in mac
buying a SSD only mac is much more expensive and is lacking SATA cable wich is hard(er) to add, looking to only replace the hdd if possible
door Roger
