Ga door naar hoofdinhoud
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
16 Vragen Bekijk alle
Why do I not have any acceleration
I have a 2005 Nissan Murano se I've replaced the alternator, the accelerator pedal sensor, the throttle control body, and the thermostat as the codes was throwing up on the obdm. I have tried clearing it out and the codes go away for a minute but come right back. I also did the relearn on it. Help me please...codes are 1122...etc actuator malfunction.....1126 thermostat stuck open...but I replaced the thermostat. I can't get the codes cleared out for some reason
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
it might be the about to alternator burn out
Was dit antwoord nuttig?
Score 1
I just started expiriencing the same issue with my nissan ive replaced the throttle body but cant get the code to clear or even accelerate but i'm working on it soon as i get it fixed i'll let you know(code 1122)
Voeg je antwoord toe
Jennifer Logan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 1,354
