Ga door naar hoofdinhoud
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
Spin Cycle will not spin
I have the Kenmore 90 Series Washer (11028922790). Washing , Rinising and draining working fine but the spin cycle does not spin. If I did a manually spin at spin cycle and then depress the timer and turn 360 degree to the same spin cycle and pullout knob (same time manually spin ) doing this few time. The spin cycle will start to spin back to spinning speed. Can you tell what's the problem.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I came across this repair clinic web site for Kenmore washing machines, and I keyed in your model no. I really hope this takes care of your problem. https://www.google.com/url?sa=t&rct=j&q=...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Good research work. If you plan on sticking around, which I hope you do, please expand your profile so we can get to know you better. Also register your name so you get the @ designation
door
Voeg je antwoord toe
John Jang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 385
