Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
no sound on speaker when the earphone jack is connected
Hello,
i have replaced a display set, the old one was damaged. After replacing all the things are running well. Only one Problem.
If i connect the flex cable from earphones jack, i get no sound from the speaker, if the cable is disconnected, i have the sound. The flex cable is new, with an old one is the same problem.
I have restored the phone, nothing was changing.
Any Ideas?
thanks a lot for your help.
Is dit een goede vraag?
Score -1
1 Opmerking
You are right, man! I cleaned the connector on the logic board with needle , there were some parts of dirt inside. But I think, the cable is out of order too, because the vibration doesn't function. I ordered a new one.
Thanks for help.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check the flex cable port on the logic board. It sounds like your phone is somehow tricked into believing that you have headphones plugged in. When you plug headphones into the headphone jack, it should tell your phone to turn off the speaker. Damage in the cable could be falsely reporting weather or not a headphone is plugged in. Also consider if you got a broken jack cable, and if necessary seek a return.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Etienne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,236
