Ga door naar hoofdinhoud
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
28 Vragen Bekijk alle
when installing new battery the horn sounds. how to stop this?
As soon as the system gets electricity, the horn sounds in an off and on pattern. How can I stop this and install the battery. Alternatively, where is the horn wire to disconnect it?
Is dit een goede vraag?
Score 2
2 opmerkingen
I am putting new battery in car . When i connect horn goes off won't
door
Check if you are connecting the correct battery terminals.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Answering my own question: Hook up the battery, then use the remote (car alarm button) to turn off the horn.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
What if you don't have a key fob
door
If the beeping persists because your key fob does not work or has a low battery itself, endure the beep until you can start the engine of your vehicle.
Score 2
2 opmerkingen:
Even when I get the car running thorn keeps beeping! Now what?
door
Start the car, put in reverse, drive and shut off the engine.
door
Voeg je antwoord toe
TWB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 86
Altijd: 26,600
