Red light stays on front camera setting lights blink
After battery change camera will turn on but the res light in the back stays on and the settings buttons flash
Is dit een goede vraag?
The number one reason most Instax cameras stop working is that the batteries need replacing. According to the manual, you can take an average of 100 shots with two new AA batteries (or around 10 rolls of film) so it is worth keeping track of just how many you’ve used up so that you can avoid any nasty surprises.
Fujifilm also advises buying batteries of the same brand/type and only using alkaline batteries.
If the batteries are dead or dying, one of two things can happen: all the lights on the adjustment dial will blink simultaneously or the red lamp will light up beside the viewfinder.
When all the lights blink, you must replace the batteries with brand new ones while the lens is extended (on other words, with the camera turned on). Note that if you replace the batteries while the lens is retracted, the lights will continue to blink.
If only the red lamp comes on, simply turn the camera off by pushing the lens back into the body and replace the batteries. Provided that the camera isn’t damaged, this should do the trick.
Was dit antwoord nuttig?
What is it’s still blinking after and get jammed
So, I replaced batteries with lens open & red lights are still blinking! What now?
Girl same!!!
I have no idea what to do thought it was my battery or memory idk what to do!!
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 181
Altijd: 29,350
