MacBook dead, not charging, new charger
Old charger was giving me trouble (mostly cable) for some time.
While working, noticed the battery going down, not charging (no light on charger connector). Decided that the cable tried to fix it (fixed it about 4 time before) - nothing. Battery discharged completely, MacBook died.
Disconnected battery, plugged Charger back. Reset SMC as was suggested.
No sign of life, no light on charger or on the front side of the MacBook, no sounds, just dead.
Very low on money, set on trying anything before taking to repair shop. Please advise!
Update (08/04/2017)
A glimpse of good news. Took the battery out, attached the charger, left the book for half an hour, it came back to life with green light on the Charger connector and power indicator in the front of the book.
Worked on the MacBook for an hour or so, decided to check the battery once more. Cleaned battery contacts, connected the battery, connected the charger - MacBook dead again.
Took the battery out, connected the charger, after half an hour MB suddenly reacted to the last of several tries and came to life again.
So, it seems the battery after all - but why such a long time before the MacBook decides to start up?
Is dit een goede vraag?
3 opmerkingen
What happens if you long press the power button to turn it on?
door Rany
The problem is not yet solved. I had to power MacBook down, then later tried to start it up again - nothing, no green lights on charger cable or the front of MB, fans aren't starting.
Dead again - and need help again. (battery is taken out).
door Alexei Zoubov
When I press the power button nothing happens at all now. Last time it came to life in a half hour or so, now it is just dead. Don't understand, I worked on it for an hour (without a battery)
door Alexei Zoubov
