Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
How can I properly re-insert the hinges?
My GBA SP can flip open, staying about 150 degrees. After I got a new shell, the screen part began to feel more heavy (loose and floppy to say the most) and doesn't make that *click* sound whenever I open or close my gameboy. I figured it would be the hinges so I reopened my handheld and disassembled most of the parts to get to them. I fixed the hinges, but the screen half still flops; bypassing the 150 degree angle to 180 and still doesn't do the clicking. I've done this numbers of times fixing them with no luck. I don't understand where the problem lies whether I improperly repositioned the hinges or that they were very worn conditioned. :\
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I never dissassembled one, but, you can try to rotate the hinges (if you can) 180 degrees, maybe is an issue of just tightening the screws a little more. Also could be the new shell, specially if its a cheapo one, are poor quality build, and most of the time will wobble and cause the problem, or if it's used, could be broken as well...
Was dit antwoord nuttig?
Voeg je antwoord toe
braxtongsp1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 3,250
