Dropped speaker, dented casing
I dropped my UE mega boom speaker and now its dented. I can live with it but it sounds like the speaker is hitting the dented part with heavy base. Is there an easy fix?
Is dit een goede vraag?
Most likely the drop was quite powerful and did some damage to the speaker too. Take the speaker out, if possible and see whether the coil is still centered around the magnet. Also check the cone for damages. It would be difficult to fix the cone or coil by yourself if they are affected; check also wiring and contacts if any. If there are electronic active parts inside then things may be more complicated.
Was dit antwoord nuttig?
Here's how to do that: https://www.bleepingcomputer.com/forums/...
Once you can get to it, see if you can press out the dent from the inside.
I droped my brothers ue mega boom speaker on my drive way and he is angry what do i do its dented ans wondering if i should fix the outer shell or buy a new one and i am woundering what the waranty guide lines are?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 3,262
