Ga door naar hoofdinhoud
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
batt ery keeps draining
I have a 2003 ford ranger a day a go the battery started draining when truck is shut off ware do I start to problem shoot ? any help would be nice thanks John.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
What's the batteries voltage? Are the POS NEG cable conn tight? When you turn the key where is the battery gage needle pointing? While driving, where is the gauge. While driving, your battery should be charging. If not, the problem could be the alternator. Most auto parts stores will test the battery and alternator for free.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
thank you sweetie for the input but both the battery is good an the alt is working grate :)
door
Voeg je antwoord toe
John Runyon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 326
