Ga door naar hoofdinhoud
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
67 Vragen Bekijk alle
Help my Google pixel XL got wet
Can my Google Pixel XL be fix without going thru the insurance. My phone got wet
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If the phone is to be saved you must open it and clean it . Just drying it out will lead to problems latter on . Dont try to power it on and dont put it in Rice ''. Use this guide to help with the teardown
Google Pixel XL Teardown
Once you've opened the phone .Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
Was dit antwoord nuttig?
Score 4
If the device doesn't power on its probably a total loss, even checking the device requires the screen assembly to be removed.
Voeg je antwoord toe
wendy mims zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 3,706
