Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Touch ID doesn't work after screen replacement
I recently did a screen replacement full with digitizer, sadly after doing this the touch ID in my iPhone is no longer functional, im using the same motherboard that came with the iPhone so it should be working. The home button does work, I restore the phone, and even changed from digitizer but nothing seems to work. Please someone help me I love Touch ID.
Is dit een goede vraag?
1 Opmerking
both the digitizer and home button dont seem damaged at all, but maybe im just looking incorrectly, is there a way to know? Please help.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I'm replying assuming it still works as a home button, clicks and takes you out of an app and back to the home screen, etc. I am also assuming you have double checked your connections, sometimes it's just a pin alignment issue and just need to be unplugged and plugged back in. If you have tried all of those things and still no luck, sometimes TouchID can be affected if you damage the long flex cable that runs along the metal plate behind the screen, connecting the home button and board. Have you checked it for any nicks or tears? If there is any damage whatsoever, you may need to replace that. Hopefully that is your issue, as it is a simple fix. :)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Marcelo Marquez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 98
