Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Ocaasionally freezes and opening apps in launch pad is too slow
System: Macbook pro 13" Mid 2012 2.9GHz i7.
Graphics: Intel HD graphics 4000
opening Launchpad is too slow but over all machine runs fine when I use lightroom/photoshop.
Booting time also increased - O/S is on SSD and all apps are installed on SSD.
Occasionally system freezes. Need to hard boot.
Took it to genius bar and they suggested that most probably motherboard is gone and they said it costs around $450
Is there any way it can be quick fixed without changing mother board and if need, is this something doable.
Also, is it really worth it? Genius bar guy is telling to live with it and instead spend money on new laptop...
System is modified almost 3yrs back to SSD and HDD (removed optical drive)
Last year upgraded SSD to 1TB.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Did the Genius Bar tell you about the Hard drive/IR cable program. They were replacing all the cables on the 2012 13" for free.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
He did not mention about changing the cables. Not sure, if this is because I modified the machine from original configuration.
Will changing those cables makes a change to slowness/freeze?
door
Search this site on this machine and see how many of this same problem there are. My bet would be about 20 to 1 it's the cable. I even keep three in stock at all times.
Here's a list of the repair questions on this model:
https://www.ifixit.com/Answers/Device/Ma...
door
I have to agree with @mayer here. These cables tend to breakdown overtime, where they are routed (bent) as well as were it rubs along the upper case. The newer version of the cable is better made..
door
Voeg je antwoord toe
sainadhb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 121
