Ga door naar hoofdinhoud
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Vragen Bekijk alle
Wifi not turning on
i am using a device galaxy note 3 -model no is n9000. Recently ,unfortunately i have damaged the memory card slot of my mobile and after that my mobiles wifi is not turning on. Please provide me some solution to resolve this issue.
Is dit een goede vraag?
Score 2
1 Opmerking
i have a galaxy note 3 to wifi is not working
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
For most all Samsung models the WiFi and Bluetooth share the same chip. This chip is generally located right above where the SIM/SD slot is located. I'm not exactly sure how damaging the slot would have done anything to that chip unless you tried changing the slot yourself and fried the chip that handles the WiFi. I've personally never fixed any of these due to the chip being epoxied in, at work they tell us just to trash phones with this failure. But whether or not a shop would have the ability to fix that, who knows, more power to them if they can.
For starters I would try a factor data reset on the phone and/or re-flashing the phone's software. It's a small chance, but it's worth taking before paying anybody. And if you have to take it somewhere to get it fixed, just know that this phone is quite old, it might not even be worth fixing anymore. For what they'd charge you, you could almost go out and buy another one.
Was dit antwoord nuttig?
Score 1
Nothing left to say about your problem. Jimmy is right. On the other hand, are you sure that it’s damaged? Maybe you just need to flash your phone? I had a similar problem, but not the same. At first, I thought that it’s something with Wi-Fi itself. But then my brother came. He’s a Cisco certified engineer. He became one not so long ago. It took a lot of time for him to prepare, but he passed exams on this https://cciedump.spoto.net/ site and obtained Cisco certification. And he told me that there was nothing wrong with my network OR my phone in the physical sense. Then I got my phone flashed and it helped.
Voeg je antwoord toe
Karan Prince zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 2,803
