Ga door naar hoofdinhoud
The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
85 Vragen Bekijk alle
How do I remove the lower radiator hose?
I am replacing my radiator in my 2001 VW Jetta and cant get the lower radiator hose off. I pulled the clip off but am not sure how to pull off the hose with out braking it since its all plastic.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
See if this video points you in the right direction.
https://www.youtube.com/watch?v=3ShCTe8Y...
Was dit antwoord nuttig?
Score 1
How do I remove parts to get to the radiator upper hoes and lower horse
Update (02/25/2018)
I went under the car and took the fan off i took off the lower hoes off but I can’t take off the upper hoes because of the clamp it’s facing up and I can get to the teeth to open it
Update (02/25/2018)
It’s the hoes from the under vw Jetta 2005
1 Opmerking:
Buy some LONG pliers "BFPs". Don't worry - Harbor Freight is cheap, & you'll use them all the time.
door
Voeg je antwoord toe
Greg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 3,450
