Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Vragen Bekijk alle
Is it possible to repair my USB port?
One of the USB ports (closest one to the user if using the laptop) does not function. Plugging any type of device, (monitor, flash drive, external hard drive, etc.) does not show up in any form on the laptop.
Is there a way to check the connection and or repair it without replacing the logic board?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
It's according to what has happened to it. As you can see in step 33 of the logic board replacement, it's soldered onto the logic board. If one of those joints has broken loose, it could be soldered back on by an experienced tech willing to do it. MacBook Unibody Model A1278 Logic Board Replacement
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Or... you can just do it yourself, not that difficult actually to do. Just like soldering on any other connector to a board
door
This helped fix my usb http://howtofixstuff.blogspot.com/2012/0...
1 Opmerking:
Don't follow that link posted by Misternoname5, that takes you to a repair option for PC users. He could have summed it up by saying "UNINSTALL" your driver for USB then "REINSTALL".
I am in the same boat with a loose USB port. I will attempt the solder technique a report back.
door
http://macs.about.com/od/usingyourmac/qt...
my middle usb port sometimes doesnt see anything plugged in but will show power on a flash drive. i reset the smc and that always fixes it. hope it fixes yours
Voeg je antwoord toe
Ryan Barry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 10,457
