Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Is it possible to replace 8GB with 16GB RAM?
Macbook Pro 13" mid 2012 A1278 2.9 GHz Intel Core i7 8GB RAM
I am thinking to upgrade my old macbook pro with 16GB RAM. Would you please specify if I do so the machine will be working fine or no?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi ....
Based on your Macbook model, a simple search says....
http://www.crucial.com/usa/en/apple-memo...
http://www.crucial.com/usa/en/compatible...
http://www.kingston.com/en/memory/search...
You need two 8GB DDR3L RAM = 16GB
Based on my experiences, either go for crucial or kingston which is specially designed for apple macbook.
there are cases using 3rd party which causes issues.
it would be good, if the shop is okay to do a in place upgrade and test on spot.
http://www.everymac.com/systems/apple/ma...
*Apple officially supports a maximum of 8 GB of RAM, but third-parties have determined that this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules.
Was dit antwoord nuttig?
Score 4
Yes, the macbook(I have one of these and have bought 16gb RAM for it) is capable of taking 16Gb or RAM modules, but ensure that you have the right frequency or it will fail. Also, you are better off just repairing it your self. The memory is fully exposed once you pop the back off. You literally only need one screwdriver to remove the back plate, the memory comes out after pushing on the tabs with your finger. There are plenty of youtube videos which will go through this.
Score 1
Voeg je antwoord toe
Egor Dyukov zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,353
