Ga door naar hoofdinhoud
iPhone 7 home Button Cracked
Hi my customer have a cracked screen and home button that stopped functioning, can the home button be replaced using the buttons sold online?? I asked the seller of the button and he said the replacement but the Touch ID will disable. Is this true? Or should I send my customer to Apple?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Better send it to Apple for the moment, because once you use a third party button the iPhone will automatically disable all home button fonctions, iPhone 7 is different from previous generations.
Assistive touch will kick in automatically once it detects a malfunction of the button even with a new home button.
Lets hope with the next iOS update they (Apple) will let us replace this part>
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Ok that's what I thought, Do you know how much apple charge for just the home button repair?
door
Here you have some prices but dont know for sure :https://support.apple.com/iphone/repair/...
door
@soros As to your comment about Apple letting us replace this part: not a chance in !&&*, they want to force you to go to them for repairs.
door
Het nuttigste antwoord
Hey Nerdchikk,
Unfortunately, with Apple making it increasingly impossible to do home button repairs, you will not be able to replace the home button whatsoever. Once an iPhone 7 home button breaks, only the Geniuses can install a new one. If you can't figure out a way to get the original to work, you're out of luck.
Score 2
2 opmerkingen:
Yea the home button is damaged with no way to fix, I will send her to Apple! Thank you
door
Is this still true or have things changed since June? I have a customer with a cracked home button.
door
Voeg je antwoord toe
Nerdchikk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 10,929
