Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
iPhone 6S refurbished screen doesn't fit from bottom
Hi, I brought a refurbished lcd for my iPhone 6S everything works fine, but the bottom of the screen is not fitting properly, the seller claims that this screen is refurbished using machines, the lcd is real but the glass is new as they fix smashed glass lcd. I don't know what to do, it's is bottom which is lifted a bit and I cannot squeeze it inside the housing. Please help.
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Is the frame dented in any way? Any warping in the frame will not allow the screen to sit properly and put unnecessary stress on the screen. You will need to bend or mould the frame into a better shape if this is the case
I would remove the stock adhesive from the top of the frame as it may be getting in the way of the hinges.
Hope this helps
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I will try it today an I will let you know if it worked
door
Voeg je antwoord toe
Mirza Zohaib zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 340
