My display is showing only lines and nothing else
My MacBook began showing green vertical lines on various areas of the display. now the display black with pink lines across it. However, when i connect it to an external display. The image is fine and no lines are shown. Is it a GPU problem or is it the display?
I tried resetting the PRAM and the SMC.. it made no difference.
Is dit een goede vraag?
4 opmerkingen
When you move the screen same result?
door Oros
Yes, when I move the screen it's the same result. I tried pressing the corners or even twisting a little but it remained the same
door jiovany
My laptop is having same problem help me out plzzz
door rkabra4u
@rkabra4u hi, check for dents on the screen lid, most likely there's a dent somewhere that was pinching on the LCD/LED screen damaging it. If there are no dents, try replacing the cable that connects the screen to the laptop. However, if the lid has a dent, you'll most likely have to replace the screen.
door jiovany
