Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
20 Vragen Bekijk alle
Where to locate CMOS battery
I'm trying to replace the CMOS battery in my Asus X555la and am unable to find the battery itself. A simple picture of the battery or a step by step guide to get to it would be great. I've completely dismantled the computer and flipped the motherboard over with no luck.
Is dit een goede vraag?
Score 4
2 opmerkingen
Hi James, have you found the solution to your problem? Is there CMOS battery on the motherboard?
door
The 555L does not have one. It has a capacitor
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If Asus is still using CMOS batteries (most companies now use a capacitor on the logic board), it may be similar to this: Asus X551CA CMOS Battery Replacement
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi i would like to know where is the CMOS battery on the asus X555QG
door
In my Asus laptop, its near on off switch, its not a big deal to replace, on the image, its near Asus logo.
Score 1
Voeg je antwoord toe
James dunne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 72
Altijd: 21,936
