Ga door naar hoofdinhoud
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Replacement digitiser now misbehaving
Replaced the digitiser after daughter cracked the screen, worked fine at first (although I didn't test the responsiveness of the entire screen - assumed if you could unlock the device with a PIN, open some apps, it was good). About a week later it seems to behave sporadically (either sometime not respond or open random apps / type random characters). Seems worse one horizontal orientation that the other. This was an aftermarket replace, could that be the cause? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Poor quality aftermarket digitizers could certainly cause this. Some of the cheap ones suffer from ghost touching as well. It could also just be improperly connected or you may have kinked the flex when you did the repair.
Lesson learned, always check the entire surface of the digi before sealing it with adhesive :>)
Take a look at the ones iFixit sells, they are good quality.
Replace a front panel assembly compatible with iPad Air. Assembly includes the glass touch panel (digitizer), blank home button, camera bezel, and adhesive. Afbeelding
Product
iPad Air Screen Digitizer
$29.99
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank you. I'm in the UK hopefully they ship here
door
Maybe you have a defective screen but before ordering another check if putting pressure on the bottom part of the screen left and right of the Home button. If this causes your screen to touch by himself the solution would be to put some tape on the little components marked with red and tape also the bottom part marked in green.
Sow you have some component on the home button flex which are not always isolated, the little cercle.
And sometimes you have the bottom part of the digitiser showing the lines which go to a segment of the digitiser that need isolation also.
Score 2
5 opmerkingen:
Great I'll give your suggestion a try. Thanks
door
Looks like this could be the problem, pressing either side of the home button causes the problem. Forgive me but its not clear to me from the photo which parts I need to cover. Do you have any other photos or instructions? Thanks
door
Only monday once i'm back at the shop, i'll add a more detailed photo to the answer
door
Thanks. Any luck with the photos please?
door
Hope it helps
door
Thanks for the advice, I tried covering the areas mentioned with tape but no improvement (pictures below). Purchased another screen which is now installed & seems to be working well, lets hope it lasts.
Voeg je antwoord toe
JohnyB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 202
