Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Vragen Bekijk alle
Vertical lines on screen
Hello, to my macbook pro 15 ", vertical lineas appear one on the screen, I have read thereabouts that if I connect it to a television and the same lines go out probably it is the graphical card but in my case it is not like that, does not show these lines in external monitors, which it might be?
Is dit een goede vraag?
1 Opmerking
They disappear for around 10 minutes and they change color, specially from violet to a light gray
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Try re-seating the LCD cables, if that does not fix it you will need to replace the LCD or top case assembly. Has it been recently dropped or damaged?
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Not that I know jaja, I will try to this and hopefully this will work, I hope so, it is incredible how an expensive machine as this one can suffer this stupid damage, thanks dude.
door
Another thing, sometimes the lines disappear, do you think this might be something of the LCD cables or more just like a damage LCD panel?
door
Do they completely disappear, or just partially? Post a picture.
door
Down there is the picture
door
1 Opmerking:
Clean the screen connectors with rubbing alcohol and make sure there is no dust.
door
This is a TAB issue. Please see this answer There is faint vertical green line on the screen
Voeg je antwoord toe
Erick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 4,938
