Ga door naar hoofdinhoud
Repair guides and support for the sixth generation of Ford F-Series trucks. Models include the F100, F150, F250, F350, and others.
18 Vragen Bekijk alle
Vraag afgerond
duraspark ICM wire connections
73 F100 Electronic distributor (no points)
Need correct wiring for each of these devices in my circuit:
Ign switch (Blk w/grn, Yellow, Red, Pink & two Red w/grn - on one terminal )
ICM (2 + 4 w/Blue square)
Starter Solenoid
Ballast (ceramic 2 terminal)
Coil (screw terminals)
Electronic Distributor
Wiring diagrams from net arent working.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Henry,
You might try contacting some of the companies that handle restoration parts for those trucks.
Here are a few I Know of. They can steer you in the right direction if they don't have it.
https://www.blueovaltruckparts.com/
http://www.lmctruck.com/index.htm
http://www.cjponyparts.com/ford-f100-par...
https://www.npdlink.com/store/catalog/19...
Like I said, they may know where to go to find what your looking for. Good luck.
Was dit antwoord nuttig?
Henry,
I'd try and contact one of the companies that handle restoration parts for your truck. If the don't have what you need they can sure steer you to who does.
1973 ford truck shop manual: https://www.fordshopmanual.com/ford-truc...
1973 ford truck parts catalog: https://www.fordshopmanual.com/ford-truc...
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 367
