Ga door naar hoofdinhoud
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
71 Vragen Bekijk alle
Replacement rear glass​?
As per the title, anyone know how easy the rear glass is to replace? The teardown shows the internals but not the glass panel on the rear... It's cracked right across my camera :(
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
you don't have to disassemble the phone to replace the glass panel. it's just glued down. Be careful around the touch id. The top side has a ribbon. It's easy other than that. Just heat it.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
What is that ribbon on the back for? I have broke it..
door
Hi,
You have to gut the insides out so take it all out to replace the back housing.
If you want to do it yourself this video will help guide you. https://youtu.be/8pmnaKEoS8A
Score 1
Voeg je antwoord toe
Karl Davies zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 10,343
