Ga door naar hoofdinhoud
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
Screen corner separated from frame
So my Xperia Z3 is just over 2 years old now and I have noticed that the top left-hand corner of the screen has separated from the frame.
Is there any way to temporarily fix it without ruining repairablility in the future?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Why not just use sticky tape to keep it together? if it's transparent enough, it might even not trigger the proximity sensor.
In any case, it will avoid more dust getting in which will progressively stick to the glue holding the screen to the frame, separating the screen more and more.
The repair will mean changing the glue between the screen and frame, which means following most of the screen replacement guide.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the advice, Axel, but I had already tryed that and, due to the case on my phone being very tight, the tape just ripped straight off.
My main concern with the corner lifting was when I remove the phone from it's case, the gap opens up to around a centimetre.
door
I generally use B7000 Liquid glue to restick the glass back to the frame as a quick and easy solution
Don't put too much and don't put too little, if you put too much you risk covering the proximity sensor, front camera on accident.
Once you have it applied, apply pressure then use sticky tape to let the glue set in between with pressure then take out the tape after 24 hours.
Rub off the excess glue if needed after that.
door
Voeg je antwoord toe
Shane Bonato zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 960
