Ga door naar hoofdinhoud
Repair guides for Android cell phones manufactured by ALCATEL.
Phone freezes while restarting
I have an Alcatel one touch and it froze the other day and when I took the battery out to restart it won't come back on at all. It will freeze on either the android symbol or the tracphone wireless screen. It won't load any further than than. Straight talk couldn't help me when I called so maybe someone on here can help please. I have factory reset multiple times and it's still not working. Help please!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
try wiping the cache partition this will give you a clear cache for a clean boot. Factory resets don't clear the cache and its apparent the boot loader that's in the cache is corrupt . To do this shut the phone off completely then hold the power button and the volume up at the same time once it powers on release the buttons and it should take you to the android system recovery .Navigate to wipe cache partition by using the volume button and when you reach the wipe cache partition press the power button to select then once it completes select reboot system now and then it should work . If this brings no joy then you will need to try updating from the same menu and if it still doesn't work then you will need to load a new ROM. Hope this helps
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Desirea Rankin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,721
